Quick comments and thoughts on SC vs. SSC
Postby _D_S_J_R_ » Fri Aug 08, 2014 9:32 pm
Just thought I'd add a few comments on these two while I still have the T.I.S.
At present, I can't listen through speakers and have spent a goodly while listening through my old HD25SP's, which are not kind to treble distortion, or treble excesses in general
The SC's found a great home here as MY general-purpose value-for-money interconnect. The cable itself is rather more expensive to buy than most screened coax cables and although the plugs don't look very posh, they actually do the job really well. My feelings on the SC remain that it's a straight down the middle kind of cable. All the musical clues are there and for detail freaks, subtle production and mixing clues can be easily heard as well!
So far, so good! I had the chance to get some cable to make my 1m (more like 1.3m as purchased) SC into an SSC. As recently discussed on AOS and here, the SSC only uses the inner cores and two cables per mono length, as using the outer screen, which is supposed to filter out rf and so on, can in theory (I understand) just transmit the interference into the system via the signal return. I dutifully got going with the soldering iron and heat gun, using small diameter heatshrink on each cable end and a larger diameter heatshrink down the length of the cables to 'tie' them together. I don't have any of that swish black woven stuff to finish it off, so didn't bother to wait to get some. PLEASE don't worry Doc, this cable ain't being passed on to anyone on the future!
OK, what's it sound like? "Really good!" is my answer. Like the SC, but more of it, I just felt the soundfield opened up a bit and just made things even easier to follow for me. I can't give reams and reams of descriptive prose about it, since it just does the job even better than SC, which can be readily upgraded by NVA should you wish to.
Next, I have to say that while I was busy with the soldering iron, I was listening through a T.I.S. interconnect, which offers a useful (necessary in a top end system) increase in musical timbre (ease of identifying) and 'texture' in the playing of said instruments. It's difficult for me to say much more, because I know that a really musically revealing system will lap up T.I.S. but for me and the gear I have, the SSC does an amazing job and I love it..
Since it's topical, I also happen to have an infamous Klotz 5000 with MS phono plugs courtesy of Brian. Pretty dire sounding from the off (worse I think than the AC110 coax they make), this cable definitely seemed to subtly get better over a good few hours' use and has ended up really good (as 'everyone else' has stated
). This one and the SSC offer two sides of the T.I.S. in my opinion, the Klotz (just the inner cores connected) sounding now very sweet, musical and spacious, whereas the SSC is just as 'musical,' but offering a precision to the mix that I and my gear like a lot!
Hang on a minute, cables are all supposed not to offer any character or 'sound' at all aren't they and only audiophools claim to hear any differences at all? These differences are admittedly very small in the scheme of things, but, for a while, if you get 'tuned in' to these types of differences, it's possible to 'get' the impressions quite well I think and I found my experiences consistent and repeatable - so there!
Forgive the clumpy writing style, I'm knackered today and when I'm like this I get a bit dyslexic too - my spell-checker works just fine thankfully - cough!
_D_S_J_R_
_D_S_J_R_
